Shifter Adjustment
Shifter Adjustment
Post by tronview on Wed Apr 13, 2011 4:07 pm
My 1975 Westy just got its transmission rebuilt and installed. With all the adjustments and new bushings, my shifter got out of alignment. I have researched several ways of adjusting it and have gotten it pretty close. But it is still not right. Does anyone have any tips or tricks to getting the shifter to work like clockwork? This is a stock shifter not a aftermarket.
Re: Shifter Adjustment
Post by DiggerD on Wed Apr 13, 2011 10:00 pm
Some good info here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=373900&highlight=berg+shifter
Post by aircooledaddicts on Wed Apr 13, 2011 10:36 pm
This is whats always worked for me
Just loosen the 2 bolts so the shifter is loose.
Put it in fourth gear and tighten down
Sometimes putting it in second works better but one of the 2 has always worked for me.
Post by Grifspop on Thu Apr 14, 2011 11:20 am
It's a type 4 motor, can't you just use 4th and reverse?
Post by tronview on Thu Apr 14, 2011 11:37 am
DiggerD wrote:Some good info here:
I saw that one. Here is anouther real good one.
http://www.thesamba.com/vw/forum/viewtopic.php?t=414719&postdays=0&postorder=asc&highlight=correct+shift+plate&start=0
