empi carb???
Page 1 of 1 • Share •
empi carb???
so got the new bus has a 1776 also the guy threw me a EMPI HPMX 40 curious if anybody has experiance with this carb would it wake up the motor a lil bit or not even worth putting it on I forget what it has on it now but ill look tommorow
daltondragger73- Dub Nut
- Number of posts: 334
Registration date: 2008-07-21
Re: empi carb???
Unless he threw you the manifold and all the other parts, you might just want to run what it came with.
bumblebuggy- Out of Control Dubber
- Number of posts: 1502
Registration date: 2008-07-24
Re: empi carb???
bumblebuggy wrote:Unless he threw you the manifold and all the other parts, you might just want to run what it came with.
OHH yeah!! he gave me the full manifold with lines drilled into it and connectors for the brake vaccum, Ive heard alot of bad about Empi so was just curious as to if its a good set up
Re: empi carb???
Worst that could happen is you put it on and it runs like crap. Give it a shot!
Re: empi carb???
the empi icts are junk the hpmx are good carbs but id look for a good used dell an have no fear of runing like crap
DOODLE BUGG- Out of Control Dubber
- Number of posts: 1290
Registration date: 2008-12-01
Similar topics» Pierburg 2E Carb
» empi carb???
» Carbs Empi / Weber
» My 69 Fastback project
» Empi Twin HPMX 44 Carbs, manifolds and linkage for sale (Weber 44 IDF copies)
» empi carb???
Page 1 of 1
