2001 jetta wagon vr6 starting issue
Post by PeeWeeMan91 on Mon Mar 21, 2011 8:45 am
Hey,
We have an issue with our jetta. its at random but sometimes when you turn the key to start it doesnt start it just turns over like its getting no gas. but some times if you give gas while starting it will start. now I done some self testing and sometimes when you turn the key to the #1 position all the lights turn on like normal but i dont hear the fuel spray and if i dont hear that it doesnt start. im confused and i dont like having this issue with my mother driving it every day. at least with the bug i can see everything going on with the jetta im left there scratching my head.
Thanks, cameron
PeeWeeMan91
Number of posts : 567
Re: 2001 jetta wagon vr6 starting issue
Post by zabo on Mon Mar 21, 2011 11:33 am
fuel pump?
Post by PeeWeeMan91 on Mon Mar 21, 2011 12:37 pm
thats what i was thinking but what about the injectors not spraying
PeeWeeMan91
Post by buggin70 on Mon Mar 21, 2011 12:44 pm
maybe the injectors are clogged
and if the fuel pump isnt pumping the injectors cant spray feul if there isnt any to spray
Post by loves trim on Mon Mar 21, 2011 1:00 pm
The fuel pump is what you should hear . You may have a problem with the fuel pump relay . Clogged injectors should not keep it from starting just make it run poor . The relay should be #409 in the fuse panel . Do you have any codes ?
loves trim
Number of posts : 258
Registration date : 2011-02-03
Post by PeeWeeMan91 on Thu Mar 24, 2011 10:58 am
A temp sensor code
PeeWeeMan91
Post by camch on Thu Mar 24, 2011 2:44 pm
on the old a3's a coolant temp sensor would case a no start at times
Post by PeeWeeMan91 on Fri Mar 25, 2011 7:41 am
So is that maybe it
PeeWeeMan91
Post by PeeWeeMan91 on Wed Mar 30, 2011 8:07 am
just another thing it really only seams to happen on the key fob i have any-other ideas
PeeWeeMan91
Post by PeeWeeMan91 on Wed Mar 30, 2011 8:08 am
and our valet key wont start the car cause it starts then shuts off and says on the lcd immobilization activated
PeeWeeMan91
