Washer Fluid Valve
Washer Fluid Valve
Post by peregrine67 on Thu Mar 17, 2011 5:22 pm
Okay I know there is a valve on the steering column somewhere that I plug in the tube to the washer fluid reservoir and from there to the sprayers. Both the tubes are loose and I can't see where to plug them in.
can anybody give me a picture or a thread to help out? I tried Samba but couldn't find it.
Re: Washer Fluid Valve
Post by peregrine67 on Thu Mar 17, 2011 5:52 pm
Wow!! I found it. Really? Do I have to take the steering wheel off and the column apart to get to it?
Post by meinvw on Fri Mar 18, 2011 8:56 am
You may be able to get to where you plug the lines in without removing the steering wheel. Guessing you do not have pressure on the system now, but if you do drain it before you start there, will give you a bath if not!
Post by peregrine67 on Fri Mar 18, 2011 11:43 am
meinvw wrote: You may be able to get to where you plug the lines in without removing the steering wheel. Guessing you do not have pressure on the system now, but if you do drain it before you start there, will give you a bath if not!
If I could get the collar off I could reach it but that collar is seriously getting in the way.
