My leaky engine
Page 1 of 2 • Share •
Page 1 of 2 • 1, 2
My leaky engine
Many of you on the forum have heard me complain about the leak i just can't find in my engine. So, I have decided to finally piece together the work i have done in the last 6 months in one topic in the hopes that someone will have a new perspective for me.
I have a 1974 Westy with a 1.8L run with a single weber progressive and 009 dizzy. I had a bargain rebuild done by Phil (Bear) of the Full Moon Bus Club about 6 months ago. I describe it as bargain b/c not all NEW parts were used. I has new solid lifters, cams, main bearings, re machined heads (they were already newish when I bought the bus), new seals and gaskets, new oil cooler (original had a hairline fracture)...ect. For the rest of the post I am going to cut and paste a communication i had with Bear....it describes all the work i did this weekend in pinpointing where the leak is located and some of Bear's thoughts as well...the leak is on the 3/4 side..
bear wrote ...
The only thing on that side would be "pushrod tubes" or a "valve cover" leaking, the oil sender shouldn't be leaking(new and checked) and the oil pump(no oil around it) is not leaking, the oil cooler & rear seal at the timing hub, is dry, so that don't leave much. I'm at a loss on it, whatever we find will make us look silly when we find it. One other place we could check is the bolt that holds the oil pick up tube in place, its between the push rod tubes on the 3/4 side, in the center of the engine, deep in a hole. I can send a picture if you don't know where it is. Phil
MY RESPONSE
Bear,
This weekend a buddy and me pressure washed the belly of the beast to assist in discovering where the leak originates. I found the bolt you were talking about (between the pushrod tubes on the 3/4 side) and it was nice and snug. Also, just poking my finger around in there revealed it was clean of fresh oil.
A day after the pressure wash (to ensure it was nice and dry) we fired up the engine, and with James underneath the bus, there was no leak UNTIL I revved the engine up to about 2000-3000 rpm. When the engine revs, the oil pukes out from the right side of cylinder #4 (driver's side cylinder closest to the rear of the bus). It is hard to see exactly where b/c there are many obstructions to our view, but it could also be just above the cylinder. There is NO oil coming from the top of the engine (dizzy is clean, oil pressure sender is clean, oil cooler is clean, dipstick is clean, oil filler tube is clean, fan housing is clean) Also, there is no oil coming from the pushrod tubes, valve cover, taco plate, oil filter, drain bolt, or from where the engine meets the tranny.
What do you think? The cylinder? Hairline fracture in the case just above the cylinder? It seems, at this point, the only way we can make a more accurate assessment is to remove the engine again, remove all the tin, remove the head and get a closer look at the cylinder?? I am perplexed yet again....Please, any advice or council will be greatly appreciated. Thanks
WHAT DO YOU GUYS THINK????
Thanks
teddy
bear wrote ...
MY RESPONSE
Bear,
Thanks
teddy
Treehive- Dub Nut
- Number of posts: 296
Registration date: 2008-07-23
Re: My leaky engine
bumblebuggy- Out of Control Dubber
- Number of posts: 1502
Registration date: 2008-07-24
Re: My leaky engine
bumblebuggy wrote:Not all that familiar with the type four. Could be a crack in the case but I'd tripple check everything again. I lean towards oil cooler though.
Everything is quadruple checked at this point, and the oil cooler is brand new (I pressure tested it b4 i put it in) with brand new seals....I wish it were that simple....and I wasn't too familiar with T4's b4 all this started, but i can find my way around now
Treehive- Dub Nut
Re: My leaky engine
if you deside to pull it out and want to run it on a crank up stand i got one you can use to find the leak just give me a call or pm
DOODLE BUGG- Out of Control Dubber
- Number of posts: 1290
Registration date: 2008-12-01
Re: My leaky engine
DOODLE BUGG wrote:if you deside to pull it out and want to run it on a crank up stand i got one you can use to find the leak just give me a call or pm
Thanx! I'm sure i will take you up on that. I'm sure the engine will be coming out again this week sometime
Treehive- Dub Nut
Re: My leaky engine
Treehive wrote:I'm sure the engine will be coming out again this week sometime
Give me a call if you need another set of hands.
peregrine67- Out of Control Dubber
- Number of posts: 1183
Registration date: 2010-01-27
Re: My leaky engine
just pm or call i will help you any way i can
Re: My leaky engine
Thanks for all the offers for help! I really appreciate that! But I had to get started last nght....if i'm not driving this bus by March, i might have a "I need to drive my bus emotional breakdown that could lead to excessive drinking"
Here is an update of the work done last night....
Well, a friend and i dropped the engine last night, stripped the tin, removed the fan shroud, and discovered the general area that the oil appears to be coming from. It is flowing down to the left of the oil pressure sending unit, but it is not the source. The oil cooler was clean and no oil is leaking from the seals. Also, it was mostly clean around the dizzy, but there was some residue....I think it flowed down there. The oil breather gasket was SATURATED with oil as well as the oil breather tube (i don't know if this is normal) however, it will be the next thing that I tackle after I pressure wash the top of the case to remove all oil residue. I really want it to be the oil breather gasket, but i expected, if that is the case, for there to me more oil residue. Could a oil saturated oil breather tube and oil breather gasket be the culprit? What would be the best way to seal the hell out of the oil breather? I will post some pics when I get home tonight. Thanks everyone!.....trouble shooting, trouble shooting, trouble shooting!
One quick question? Is is safe for me to put the engine back in the bus and run it without the tin? I have a feeling that will be the only way to solve this perplexing issue.
thansk
teddy
thansk
teddy
Treehive- Dub Nut
Re: My leaky engine
You talking about just for testing purposes, or to drive it around like normal? Just doing short runs for testing purposes, I think you'll be fine, but I probably wouldn't do actual road driving for extended periods without the tin.
Bocephus yields to no one!
1966 camper bus
fluxcap- Dub Lieutenant General
- Number of posts: 2408
Registration date: 2008-07-20
Re: My leaky engine
I wouldn't let it run much more than a minute. But a quick start and rev shouldn't kill it. Try cranking it by hand or just running the starter after you clean it to see if moisture is developing.
Re: My leaky engine
Yeah, I was just talking about running it (not driving it)....it seems that without the tin in place, once i run it, if it is the oil breather, I will be able to plainly see the oil flow with my head shoved in the engine compartment....I don't think we would even need to run it for more than a minute or two and rev it up to expose the leak....I think we are getting real close....and a huge POSITIVE, if I can't find the leak, Bear has a loaner engine to give me while he troubleshoots the leak!
Treehive- Dub Nut
Re: My leaky engine
I've run a few T1 engines in the car with nothing at all but the carb and dizzy on top, before just to see where leaks were comming from. no more then a minute tho. (no fanshroud, alternator, tins, etc.). i had two box fans pointed at it tho, just to be on the safe side. It won't hurt anything, and you should be able to find the problem within a few seconds anyway. this is what i'm about to do to my 2074cc motor. I'm going thru a quart of oil every 2 hours of driving now
Bugman114- Dub God
- Number of posts: 2322
Registration date: 2008-08-09
Re: My leaky engine
So I took my engine back to Bear last night and we tore down the driver's side. I had already stripped it of all the tin and exhaust. So we took the head off and removed the cylinders, and found what I F**KING HOPE is the problem. The lip on the case where the #4 cylinder sits had a small speck of metal sticking out (like a teeny tiny thorn). There was also a small depression. These two factors could
be causing the cylinder to leak. So we removed said metal speck, rubbed the surface a bit, and used some kind of sealant (red goop) before we put her back together (I can't remember the name of the sealant, but Bear seems to think it will work)....anywho, if this doesn't fix the problem, both Bear and I believe it would have to be a fracture in the case that we cant see with the naked eye.
Regardless, Bear has assured me that if this does not fix it, he will use one of his other cases and take the guts out of my engine and swap with the new/used case. Also, he has a complete runner that I can use in the interum so I can make it to Springfest next month....I'm putting the engine back in this weekend, so I'll keep everyone posted....peace
teddy
teddy
Treehive- Dub Nut
Re: My leaky engine
Give me a shout if you need a hand putting it back in.
Re: My leaky engine
Good luck with it. You cannot deal with anyone as good as Phil. It sounds to me like it would be the cooler or pressure switch but you guys covered that.
meinvw- Complete Dub Addict
- Number of posts: 863
Registration date: 2008-11-22
Page 1 of 2 • 1, 2
Similar topics» eml mini jumbo with kx 500 engine
» Shumaker Stage 2 Engine Cases 4.375 Bore
» 1940 Indian Chief engine Wanted
» My leaky engine
» W - 4G92 Mivec Engine
» My leaky engine
Page 1 of 2
