correct throw out bearing?
Post by vwtattooed on Thu Dec 23, 2010 5:33 pm
when i order my clutch kit i am not sure which T.O bearing to order....the engine is from a 70 Bus...the trans is from a 71 Bus. all the kits i have seen are different between the 2 years. any advice???
Re: correct throw out bearing?
Post by zabo on Thu Dec 23, 2010 5:37 pm
if the trans is a 71 id get the later style throwout bearing- engine year doesnt matter. If you get the later style throw out. use the pressure plate without a collar
Post by camch on Thu Dec 23, 2010 6:31 pm
i think it has something to do with the muffler bearing ,make sure they match
Post by Muffler Bearing on Thu Dec 23, 2010 6:48 pm
camch wrote:i think it has something to do with the muffler bearing ,make sure they match
If you need any help with this let me know.
Post by DOODLE BUGG on Thu Dec 23, 2010 8:41 pm
clutch kit needs to be for a 71
Post by vwtattooed on Thu Dec 23, 2010 9:10 pm
ok so i should just order the kit for a 70 model with the old style T.O. bearing? just wanna make sure so i don't have any issues...i ain't pullin the motor back out AGAIN!!! if something else goes wrong this thing will be gone from here...lol! Twisted Evil
Post by Attorney Isaiah Loophole on Thu Dec 23, 2010 9:42 pm
if the tranny has a collar around the output shaft order the 71 kit.....if no collar then order the 70 kit
Number of posts : 4930
Post by vwtattooed on Thu Dec 23, 2010 9:59 pm
it HAD a guide that bolted to the trans with 3 bolts, that was ripped out with all the other guts!! i found the guide and a clutch kit on CIP1 website but they ask which style T.O Bearing i need...early or late...up to 70,71 and up.
Post by Attorney Isaiah Loophole on Fri Dec 24, 2010 9:03 am
you need to get another guide and then get the 71 (later style) throw out bearing
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-311-140-025-DKIT
and one of these
http://www.thesamba.com/vw/classifieds/detail.php?id=899876
