BUS SHIFT ROD
BUS SHIFT ROD
Post by vwtattooed on Wed Nov 24, 2010 7:20 am
does anybody know which way the offset knuckle at the back of the shift rod where it meets the trans should be turned? offset up or down??? i removed the shaft before and did'nt think it would be going back in so payed no attention during removal! scratch
Re: BUS SHIFT ROD
Post by peregrine67 on Wed Nov 24, 2010 10:30 am
I don't know either, but when I get home I can crawl under and check for you if nobody else answers before then.
Re: BUS SHIFT ROD
Post by vwtattooed on Wed Nov 24, 2010 8:34 pm
that would be great..thanks!!
Re: BUS SHIFT ROD
Post by peregrine67 on Thu Nov 25, 2010 6:58 pm
It appears to be offset down. I've got a '76. Hopefully yours is the same and this helps you out.
Re: BUS SHIFT ROD
