Removing Axles from Trans
Post by 57RTOval on Sun Nov 14, 2010 1:45 pm
Before I do something difficult to undo, I thought I'd better ask. I've checked Muir's book and my trusty VW shop manual and I'm still not clear on which nuts to remove. To remove the axles from the trans, do I need to remove the 8 nuts circled in blue? I removed the 6 nuts circled in yellow which gave some in/out play to the axle but it would not come out. I didn't want to take apart anything I didn't have to and/or have the diff fall out on the floor. Thanks!
57RTOval
Number of posts : 529
Re: Removing Axles from Trans
Post by Attorney Isaiah Loophole on Sun Nov 14, 2010 1:52 pm
Remove the yellow ones and the axle tube will come off....if you want to remove the axle you have to remove the tubes then the circlip that holds the axle in the tranny
Post by 57RTOval on Sun Nov 14, 2010 5:00 pm
I knew there had to be something I was missing. Thanks Bryce.
57RTOval
Post by 57RTOval on Sun Nov 14, 2010 7:34 pm
57RTOval
