Daytona WinterJam 2011
Page 7 of 7 Previous  1, 2, 3, 4, 5, 6, 7
Re: Daytona WinterJam 2011
Post by B.B. on Tue Mar 01, 2011 9:38 pm
overspray wrote:Awesomes pics... I didnt make it to WJ show layed on the beach all day.... and dug a stuck lil 65 (BB) out !
GOOD TIMES ! ! ! Had a blast @ NDBS and watching you dig a stuck lil BB out of sand ! ha....
GRITS Gurls !
B.B.
Number of posts : 115
Registration date : 2010-04-25
View user profile http://www.gritsvw.com
Post by kstanle2 on Wed Mar 02, 2011 9:19 pm
kstanle2
Number of posts : 15
Registration date : 2010-10-02
Post by callahan on Wed Mar 02, 2011 9:32 pm
kstanle2 wrote:
jolene about 40 or so years ago haha
Post by Grifspop on Wed Mar 02, 2011 10:00 pm
callahan wrote:
Jolene Pre-Hoodride
Post by callahan on Wed Mar 02, 2011 10:13 pm
that thing was soo nice bone stock except for the sweet slam job of course
no doubt one of the cleanest cars there
Post by Tanbug on Sat Mar 05, 2011 11:25 am
fluxcap wrote:
Knumb Knucks wrote:
fluxcap wrote:Back to mcdonough safely.......finally. had to make three "pitstops" for fuel delivery issues. Huge thanks to the Addicts and Bobby for all their help and patience on the trip home, hope the rest of your trip wasn't too rainy.
Leaving the bug at Kelly's moms house for a few days until I can get back with another fuel pump.
I've got a few pics I'll get up in a day or so.
I had fuel troubles too,frikn vapor locking on me.Got it cleared up as well.
Mine may be vapor lock as well. I already have another fuel pump so I'm going to switch it out and see if that works. It ran like a champ when it was running. But if I cut it off for a few minutes (gas station fill-ups), and then restarted it, it would run until the bowl went dry and then die. Pulled the line to the carb and cranked the engine over, and the pump wouldn't pump anything out. The last time it happened, Bobby made a make shift funnel, and we filled the carb bowl to get gas in there. Once it was full, we cranked it, and the pump started pulling gas through.
Did you have too many gaskets under the fuel pump from earlier issues?
Tanbug
Number of posts : 86
Registration date : 2010-05-19
Post by overspray on Sat Mar 05, 2011 12:01 pm
Nice sig line Tan !! cheers
overspray
Number of posts : 381
Post by Tanbug on Sun Mar 06, 2011 10:17 am
overspray wrote:Nice sig line Tan !! cheers
Some things never change.
Tanbug
Post by fluxcap on Sun Mar 06, 2011 10:37 am
Oh I had a crap ton of gaskets under there!!! At least 8, and the pushrod had been shaved down a few mm as well. Only way I could ever get the pressure to around 3lbs. I put my alternator style fuel pump on yesterday and was able to get rid of all the extra gaskets.
The second and third time it happened, we had been hauling butt for a real long period of time, so I can kinda understand it maybe getting a little to hot. But the very first time it happened, we had only been on the road for about 40 miles??? Of course that time it re-started after only about a minute though.
Post by Tanbug on Sun Mar 06, 2011 8:17 pm
All those shims cut down on the fuel delivery to the carb, also check that vent tube at the filler cap is not plugged.
Tanbug
Post by fluxcap on Mon Mar 07, 2011 6:34 am
Yeah, hopefully this new pump will be better without so many shims! I did pull the vent tube out from where it exits the front apron and blew through it. It was nice and clear. I'll be giving it a good drive this weekend for the Reynolds trip, so we'll see how it goes!
Last night I swapped back over to the aftermarket fanshroud and put in the alternator I got from you. Still got to wire it up and get the belt on. Just wanted to go on and swap it over and make sure it was all nice and lined up correctly BEFORE we tackle those carbs again.
Post by Tanbug on Mon Mar 07, 2011 9:39 pm
Couple of weeks.
Tanbug
Post by fluxcap on Tue Mar 08, 2011 6:38 am
Tanbug wrote:Couple of weeks.
Sounds good!!! Very Happy
Post by 64 Deluxe on Tue Mar 08, 2011 6:39 am
[quote="B.B
GRITS Gurls !
[/quote]
I had a great time hanging out with my fellow GRITS gals Very Happy
64 Deluxe
Number of posts : 58
Registration date : 2010-08-18
Post by B.B. on Tue Mar 08, 2011 7:31 am
cherry Ditto Kat ! And thanks for the cool G.R.I.T.S dog tag !
B.B.
Post by 64 Deluxe on Wed Mar 09, 2011 8:19 am
you're welcome flower
64 Deluxe
Post by Major62 on Mon Mar 21, 2011 10:08 pm
Eric found this one when you and Bobby were in action - still need to get me some of that windex starter fluid !!
Major62
Number of posts : 285
Post by fluxcap on Tue Mar 22, 2011 6:41 am
Haha, doesn't look like I'm in much action here, I can just barely see my shoe in the left margin. Laughing Bobby is doing all the hard work. The windex bottle worked much better than the plastic cup! I've been waiting for these pictures to surface. Haven't had any starting problems since putting in the new fuel pump. It'll have a good long test run up and down to BAP next month.
