help needed
help needed
Post by airhead88 on Tue Oct 05, 2010 10:28 pm
how would i adjust the shifter linkage on a 92 jetta 1.8 5 speed
airhead88
Number of posts : 32
Registration date : 2009-06-06
Re: help needed
Post by LungTube on Fri Oct 22, 2010 9:21 pm
http://www.strictlyea.com/features/diyshifter.html
LungTube
Number of posts : 110
Registration date : 2008-10-28
Re: help needed
Post by airhead88 on Tue Oct 26, 2010 12:28 pm
LungTube wrote:http://www.strictlyea.com/features/diyshifter.html
thanks man
airhead88
Re: help needed
Post by bakertim2 on Tue Jan 04, 2011 8:50 pm
I need some help with a 91 Jetta, I recently purchased. It needs some wiring issues straightened out, among other things.
Re: help needed
Post by vwovalchild on Tue Jan 04, 2011 11:13 pm
Come on BKR...... you can do anything
Re: help needed
Post by meinvw on Wed Jan 05, 2011 10:10 am
bakertim2 wrote:I need some help with a 91 Jetta, I recently purchased. It needs some wiring issues straightened out, among other things.
Just smack the dash occasionally, should fix most of them! Laughing I do not think I have ever owned a vw without some kind of wiring problems. The 80's-90's were the worst. What are the problems with it?
Re: help needed
Post by bakertim2 on Wed Jan 05, 2011 2:36 pm
It doesn't have power to the switch side of the starter and I cant hear the fuel pump running.
Re: help needed
Post by LungTube on Tue Jun 07, 2011 9:02 pm
Auto or manual? if its auto then neutral safety switch either way make sure your seat belt is connected(on). its got a switch in it and not clicked no start.
LungTube
Re: help needed
Post by vwtattooed on Tue Jun 07, 2011 9:21 pm
if it has the shoulder belt in the door, the car will not start unless the belt is hooked up! as stated also check neutral safety. most likely seat belt tho.....
Re: help needed
