exhaust question
exhaust question
Post by buggin70 on Sun Sep 26, 2010 6:26 pm
umm i didnt know where to put this so ill ask it here
if i buy a header muffler does it usually come with the gaskets?
or should i buy them separate?
Re: exhaust question
Post by Bugman114 on Sun Sep 26, 2010 8:54 pm
I'd buy them seperate. they usually come with those shitty paper gaskets, and not the good metal ones. the paper ones blow out, and leak, even on a stock motor.
Post by buggin70 on Sun Sep 26, 2010 8:59 pm
thats what i was thinkin just wanted another opinion
Post by mrfeather on Fri Mar 22, 2013 11:45 am
I have A Gene Berg built engine and don't want to kill it buy changing the exhaust and not letting it breath properly. The issue that I have an exhaust that to loud for the car and me. If anyone has a suggestion I am open to them.
mrfeather
Number of posts : 176
Post by Attack chicken on Fri Mar 22, 2013 1:15 pm
mrfeather wrote:I have A Gene Berg built engine and don't want to kill it buy changing the exhaust and not letting it breath properly. The issue that I have an exhaust that to loud for the car and me. If anyone has a suggestion I am open to them.
What exhaust do you have now? A1 makes nice systems and if you have a Berg engine spending on a A1 would be inline. Here is a link to a vender with the set up. You will need the header and muffler.
Header
http://www.piersideparts.net/A1SWHT.html
Muffler
http://www.piersideparts.net/A1HT200.html
J pipes if you are not running heater boxes
http://www.piersideparts.net/A1JTUBES.html
These are not cheap items BUT you do get what you pay for. Don't get a header with pipes that are too big, muffler either for that matter, most people want the biggest of everything and that is not the best way to pick a exhaust.
Attack chicken
Number of posts : 104
Post by Attack chicken on Fri Mar 22, 2013 1:31 pm
buggin70 wrote:umm i didnt know where to put this so ill ask it here
As Bugman said it will probably come with gaskets but beware what muffler you get, if it says EMPI it won't be much of a muffler. I have seen those last less than a year before there was a 2 inch rust hole(in the South not due to salt). The fitment is poor as well.
Attack chicken
Post by sploval53 on Fri Mar 22, 2013 2:39 pm
Buy ceramic. Well worth the money
Post by Bugman114 on Fri Mar 22, 2013 4:56 pm
I like those black squishy gaskets cb performance sells. I believe they are either graphite or carbon, or something like that, I forget which. I used them on the last couple of motors I built. No leaks, even on old warped exhaust flanges o.O
I just wish I remembered to buy them for this motor I'm building for my rail TT~TT
Post by camch on Fri Mar 22, 2013 5:07 pm
If you can find aluminum use them first. If not get copper.
Post by DiggerD on Fri Mar 22, 2013 8:02 pm
Vintagespeed.
I have one of Mr. lee's exhausts on my bus. All stainless, quiet, but it is a little pricey. Well worth the $ tho...
Post by Major62 on Fri Mar 22, 2013 8:11 pm
camch wrote:If you can find aluminum use them first. If not get copper.
Agreed not the cheap ones most send with the muffler
Major62
Number of posts : 285
Post by type4revolution on Fri Mar 22, 2013 9:23 pm
CB gaskets X20
Post by Bugman114 on Sat Mar 23, 2013 9:00 am
Do you mean the solid or crush type? Which ones do you use? I tried some cb solid copper gaskets before and all they did was leak, tho my flanges prolly weren't 100% flat. Might have worked better on a new exhaust with perfect flanges, idk. I also couldn't get the exhaust nuts to stop loosening up and falling off even with lock washers. I eventually put some lock nuts and that worked, but it still leaked.
Post by MRJEL on Sat Mar 23, 2013 9:11 am
I was in a tight once, didn't have a gasket for an old tractor. I did have some leftover aluminum/vinyl flashing from the home repair.
Two gaskets, pvc to pvc and it hasn't blown in over 10 years!
MRJEL
Number of posts : 220
Post by type4revolution on Sat Mar 23, 2013 3:16 pm
There new soft crush gaskets last long tiime you have to make sure your flanges are flat for correct seal
Post by camch on Sat Mar 23, 2013 4:51 pm
If you use aluminum they are solid if you use copper use crush
