starter problems
starter problems
Post by skunk on Thu Sep 02, 2010 7:10 pm
took my trans. outa my bug 2 put a new 1 in.i put the starter in the new one and its starts grinding and makin all kinds of stupid noises.took it out put a new brass bushing in.now it makes a loude buzzing noise while grinding.it will start the car but i would like to know if anybody knows wat it cud be. thanx, skunk
skunk
Number of posts : 218
Re: starter problems
Post by Bugman114 on Thu Sep 02, 2010 7:21 pm
swing axle? IRS? 6V? 12v? is it just when you crank it, or all the time while running? how do the teeth look? are allt he bolts tightened down? Once, i didn't line up the D bolt right, and tightened it, and it vibrated till it fell into place and lossened up, causing my starter to make all kinds of funny noises. maybe post a youtube vid of the car making the noise.
Post by DOODLE BUGG on Thu Sep 02, 2010 10:38 pm
try an auto matic starter thats the best thing since sliced bread
Post by Bugman114 on Thu Sep 02, 2010 10:50 pm
true that. It's really sounding like the starter itself, especially if its actually starting the motor. yank the starter out, and have it tested at any autoparts store, and see if it makes the noise on the machine.
Post by DOODLE BUGG on Thu Sep 02, 2010 10:54 pm
most parts stores and starter shops cant test the starters with out a bell housing because of the pilot auto matic is the way to go
Post by ASBug on Fri Sep 03, 2010 12:25 pm
DOODLE BUGG wrote:try an auto matic starter thats the best thing since sliced bread
Amen!
Post by skunk on Fri Sep 03, 2010 5:43 pm
its a 12 volt swing axle. an only does it wen i crank it.noise goes away wen running.its a new starter.worked fine a month ago.ive checked the bolts an everythings tight as i can get it.ill take it bak off and try the auto stores.ill take a bell housing with me lol....thanx yall
skunk
