stinger dimensions
stinger dimensions
Post by callahan on Tue Aug 24, 2010 2:05 pm
i've got something in the works right now and need to know the dimensions of a stinger if someone could help me out
just general stuff like length, diameter at both ends, and and what gauge metal is used
any help would be sweet!
more info and pics to come
Re: stinger dimensions
Post by buggin70 on Tue Aug 24, 2010 8:00 pm
I just measured Drew stinger. The dimensions of the stinger is its seventeen inches long, with a diameter of two inches to three inches. The gauge is unknown.
marie just typed that.
Post by Bugman114 on Tue Aug 24, 2010 8:16 pm
I've got three different stingers at home. One is designed to fit under the apron, it has a curve out of the flange, so it sits lower, and its shorter then most i've seen. the other is the long one, you normally have to cut the apron for, and its alot longer, and the other, has a big angle on it, i was told it was for a baja, kinda like those tall exhausts a lot of baja's have where the pipe goes straight up, except it has a flange, instead of held on by springs.
i'll try to get dimensions of each tomorrow
Number of posts : 2460
Post by callahan on Thu Sep 16, 2010 12:12 pm
well i said i had something in the works and i finished it up this morning
just need to get a flange and its ready to bolt up
here it is and as far as i know the first and only. . . copper stinger!!!
its far from perfect but its gonna be sweet none the less
i'm trying to figure out if there is something i can coat it with to keep it from corroding too bad
Post by drewBAKER on Thu Sep 16, 2010 1:00 pm
damn that's sweet!
Post by peregrine67 on Thu Sep 16, 2010 3:17 pm
Are you doing a Steampunk Baja?
Post by drewBAKER on Thu Sep 16, 2010 3:43 pm
no its going on his 65 bug now
Post by callahan on Thu Sep 16, 2010 5:01 pm
peregrine67 wrote:Are you doing a Steampunk Baja?
lol no but i am a huge steampunk fan
i was thinking about doing some more copper stuff for the engine bay
coil cover? air cleaner? maybe some other little things
Post by buggin70 on Thu Sep 16, 2010 5:27 pm
use some flat clear
or gas tank sealer in and out
Post by callahan on Thu Sep 16, 2010 5:35 pm
gas tank sealer may work
im pretty sure the clear would just burn off though lol
maybe some polyurethane?
Post by Cambur on Thu Sep 16, 2010 6:36 pm
thats sick Callahan! good work!
Post by peregrine67 on Thu Sep 16, 2010 6:47 pm
My wife and kids want me to completely steampunk our Westy.
Post by callahan on Thu Sep 16, 2010 7:07 pm
do it!!!!!
Post by Grifspop on Thu Sep 16, 2010 7:18 pm
I would let nature do a patina job on the copper and turn it green, that would look cool
Or, see if you can find some high heat paint in clear
Post by peregrine67 on Thu Sep 16, 2010 7:36 pm
do it!!!!!
At this point I'm just going for making it a reliable daily driver. But I'm defiantly considering it.
http://steampunkworkshop.com/bus1.shtml
Post by callahan on Thu Sep 16, 2010 8:33 pm
well the clear duplicolor high heat paint the guy at advanced recommended didn't work at all lol
it made it all hazy and it looks like it did before i polished it
if anyone has any suggestions shout it out lol
i'm gonna try and wet sand and buff the clear and see what happens in the morning
Post by callahan on Thu Sep 16, 2010 8:43 pm
do it!!!!!
thats sweet i really dig all the steampunk stuff
when i build a motorcycle it will probably have a good bit of steampunk influence lol
like these
Post by DOODLE BUGG on Thu Sep 16, 2010 10:10 pm
that bike would be like puting a bomb between you legs
Post by callahan on Thu Sep 16, 2010 11:06 pm
DOODLE BUGG wrote:that bike would be like puting a bomb between you legs
lol yeah the first one is 1440cc and the second is 1000cc
the two biggest single cylinder bikes
Post by callahan on Thu Oct 21, 2010 5:41 pm
well finally got my header today and put it on with the stinger i made
it looks nasty and sounds even nastier
Post by bakertim2 on Thu Oct 21, 2010 7:05 pm
Thats pretty flippin sweet
Post by drewBAKER on Thu Oct 21, 2010 9:37 pm
i cant wait to hear this beast.
Post by kstanle2 on Thu Oct 21, 2010 9:54 pm
I like it. Smile
kstanle2
Number of posts : 15
Registration date : 2010-10-02
Post by 67vdub on Thu Oct 21, 2010 10:10 pm
looks good you should get some cool color off the heat from the stinger..
