HELP ME I BEG YOU
HELP ME I BEG YOU
Post by inkaddict13 on Sun Aug 22, 2010 7:06 pm
I need some help I will give you gas money....bow down whatever ...i boughta 75 bettle baja with a 70 motor in it and i cant seem no matter what i try to get the carb right.....my dwell tach is trashed and i am at my wits end...if anyone could come over and adjust this carb for me i would be truly greatful and as i said i will give you some gas money...the carb is a pict30...i want to drive it to work tomorrow so bad please help....i am on my knees begging Sad ....my number is 678-878-1886 if you can help...thanx bom
inkaddict13
Number of posts : 7
Registration date : 2009-11-24
Re: HELP ME I BEG YOU
Post by Attorney Isaiah Loophole on Sun Aug 22, 2010 7:45 pm
I can probably help you tomorrow but not today
Number of posts : 4923
Post by Bugman114 on Sun Aug 22, 2010 8:32 pm
if ya want to mess with it yourself, its not too bad. just twist the big screw in till it idles good, then adjust the little screw till it sounds right. screw it in till it starts to bog, then back out till it runs good, and boggs again. Try and find the "middle area" Give it a good rev after each adjustment to see how it sounds. Also, be sure to get the motor nice and warm. never adjust when its cold. If the adjustment screws don't seem to be having any effect, then there may be something wrong with the carb.
remember, the fat screw is the idle adjustment, and the little one is the mixture screw.
Hope this helps. it usually takes me a while to actually get it spot on (over 30 minutes of messing with it), lol. whereas it takes jason at IAS like 30 seconds to get it spot on, lol.
