Play in steering
Play in steering
Post by peregrine67 on Wed Jul 07, 2010 9:24 pm
Now that I've been driving her daily I've noticed that the bus has about 15 degrees of play in the steering. I doesn't bother me, I learned to drive on a Dodge van that was much worse. My question is; can this be fixed? If so, how? Is it a symptom of a more serious problem? Or should I just be happy it's not any worse? Very Happy
Re: Play in steering
Post by DiggerD on Wed Jul 07, 2010 10:49 pm
Jack it up and get under there while someone quickly rocks the steering wheel back and forth, the freeplay should become apparent using this method. My guess is probably the drag link.
Post by peregrine67 on Thu Jul 08, 2010 6:56 am
I'll check it out this weekend. Thanks Digger.
Post by bumblebuggy on Thu Jul 08, 2010 8:47 am
Or the center pin or the box could use adjustment.
Post by 71_georgia_beetle on Thu Jul 08, 2010 7:51 pm
I had some play and it was a crack in the rubber damper.
Post by peregrine67 on Wed Aug 18, 2010 6:30 pm
71_georgia_beetle wrote:I had some play and it was a crack in the rubber damper.
I finally got around to checking this and it looks like that's exactly where the play is.
