Drop extensions
Drop extensions
Post by Attorney Isaiah Loophole on Fri Sep 05, 2008 12:04 pm
Figured I would post these up. --->Drop Extensions
Basically you can lower your car with a bolt on part and still retain full suspension, no cutting of springplates!
Re: Drop extensions
Post by 39coupe on Fri Sep 05, 2008 12:36 pm
I've been looking at a beetle set to lower the rear of my '65 but am uncomfortable cutting the stock shock mounts off. I have never lowered a bug before and I know you have Bryce, what are your thoughts on doing this vs just dropping a click the old fashioned way.
39coupe
Number of posts : 455
Re: Drop extensions
Post by Attorney Isaiah Loophole on Fri Sep 05, 2008 1:01 pm
If you are going just one click then go one click on the torsion. If you are going lower then use this with adjustments on the torsions. I do like the idea of these and I have an extra set of axle tubes so cut away!
Re: Drop extensions
