'64 Sunroof "Geek"
Page 6 of 8 Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Re: '64 Sunroof "Geek"
Post by drewBAKER on Mon Oct 18, 2010 11:47 pm
i think the 65 was the first year that went to the changed shift rod. So the 64 shift rod should work. Unless the 64 shift coupler is different from the 58-59 shift coupler.
Post by rpm750 on Tue Oct 19, 2010 7:12 am
I have the '64 pan and it has a plastic bushing. It also had a different shifter coupling, it uses the square cage coupler.
Post by zabo on Tue Oct 19, 2010 8:43 am
what transaxle are you running?
Post by drewBAKER on Tue Oct 19, 2010 9:19 am
you need to use the shift rod that goes with the pan. i changed out my shift coupling to a Empi urethane coupling and the bolt holes didn't match up which made it impossible to find 1st and 3rd.
So i put everything that was stock back in, and now everything works fine.
So i would say make sure everything is the SAME.
Post by rpm750 on Tue Oct 19, 2010 12:06 pm
Zabo the '64 trans. I said that the coupler was for a '64 but I believe that it is from the '58-'59 pan.
I'm baffled..... Question
Post by rpm750 on Fri Nov 12, 2010 9:05 pm
First real cruise for Geek. He's a pro.
Post by zabo on Fri Nov 12, 2010 9:12 pm
how did you fix the coupler problem?
Post by rpm750 on Fri Nov 12, 2010 10:11 pm
I'm not running a plate under the shifter. It is hard to get it in 2nd. It shifts good just can't do it fast. Still baffled by the problem though.
Post by rpm750 on Sat Jan 29, 2011 7:39 pm
Well haven't posted much about Geek lately but I have installed Bumpers....
Also I've been working on the interior. I used most of the cash I got from the sell of O'Bugga to purchase it. I went with this stupid sport seat. What a mistake!!! I have chopped up a drivers seat bottom frame so my head doesn't stick out the freaking sunroof. The padding is so damn thick that you will sit bout 3 inches higher and forward.
Here is the seat and door panels. Headliner had to be sent back to TMI and I'm still waiting on it to come back. Use some other company TMI sux!!! I must say though the seat is comfy.
It is dark grey with Light grey tweed.
Post by Attorney Isaiah Loophole on Sat Jan 29, 2011 7:49 pm
Geek is looking good!
Post by DOODLE BUGG on Sat Jan 29, 2011 9:13 pm
looking good bob i think you should paint the bay black an white an have a geek bus
Post by 63buggin on Sat Jan 29, 2011 9:44 pm
Looking great bob......... When are you going post some bus pics
63buggin
Number of posts : 119
Post by Attorney Isaiah Loophole on Sat Jan 29, 2011 9:50 pm
63buggin wrote:Looking great bob......... When are you going post some bus pics
Look in the 70s section....
Post by 63buggin on Sun Jan 30, 2011 7:23 pm
Thanks Bryce
63buggin
Some days are just bad days!
Post by rpm750 on Fri Mar 04, 2011 3:20 pm
I've been parking in this spot a couple of days b/c the Bus is in the garage. Well my daughter backed out the drive pulled back in left again and pulled back in and then forgot Geek was there. Yeah she was very upset. Well I am too a bit but things like this happen, I feel 50% responsible because of my decision to park here. This morning, I took the day off to work on the Bus, something told me to move it but I didn't.
I pulled it into the garage and removed the fender. Took it down to the shop and sanded it, beat out all the dents, there were a few existing, got it close and I'll straighten the quarter as best as possible and then refine the fender. It looks really good considering. I'm concerned about the quarter panel is is pushed in at the top a good bit. Got my new bumper a bit also.
Post by fried_chicken on Fri Mar 04, 2011 3:23 pm
ouch! Sad
Post by fluxcap on Fri Mar 04, 2011 3:32 pm
Awe man I hate too see that Bob. I'm sure you'll get it straightened out pretty good.
Post by Grifspop on Fri Mar 04, 2011 4:54 pm
That sucks, Bob, at least no one was injured in the accident
Post by bakertim2 on Fri Mar 04, 2011 10:03 pm
Sorry to see that Bob. That's gotta hurt... Crying or Very sad
Post by DOODLE BUGG on Fri Mar 04, 2011 10:15 pm
that sux bob i have a fender you can borrow till u get one so you can ride you can spray paint it black to if you want i got them for my 7 but it will be a minute on that carjust let me no
Post by rpm750 on Fri Mar 04, 2011 10:26 pm
Well I don't sit around on my hands, I like to knock crap like this out!
A few progress pics.
Post by callahan on Fri Mar 04, 2011 10:53 pm
looks good bob! keep it up and we'll never be able to tell before long
Post by fluxcap on Sat Mar 05, 2011 7:51 am
These quarter panel pictures look all to familiar! Keep at it, it can be smoothed out nicely.
Post by DOODLE BUGG on Sat Mar 05, 2011 8:40 am
dang man you are one bad mofo
Post by rpm750 on Sat Mar 05, 2011 9:41 am
Yeah Eric I thought the same thing when I walked outside and look at it.
I didn't want to mess with the wht paint but I think I'll go ahead and strip that area and fix it right. The fender is tweaked a bit but with some persuasion I'll get it back in place.
I had planned on removing this fender and fixing the dent that was in it. The filler had cracked and water was getting in there. I need to remove the hood and left rear fender they have rattle can paint jobs on them. Maybe after Reynolds but before BAP?
