Transmission Oil
Transmission Oil
Post by panic_fan on Mon Aug 24, 2009 3:00 pm
Wondering what type of Gear Oil you guys suggest for the Bus? (1970) I tried searching on the samba but couldnt really get a direct answer. Im thinking about giving the trans some fresh juice!
Most were saying 80W-90 GL-4. Does that sound correct?
Thanks!
panic_fan
Number of posts : 410
Re: Transmission Oil
Post by bumblebuggy on Mon Aug 24, 2009 3:35 pm
Sounds right. You'll need about a gallon.
Post by ASBug on Mon Aug 24, 2009 4:54 pm
Just make sure that you can get the fill plug out BRFORE you drain it...
Just my $0.02.
KC Very Happy
Post by bumblebuggy on Mon Aug 24, 2009 5:33 pm
Not an issue in a stock height bus. You will need the pump that fits on the bottle. They sell them at just about every auto parts store. It screws onto the bottle and has a clear hose that you run to the fill.
Be aware the stuff smells like rotten eggs :Blah: so try not to make a big mess.
Post by panic_fan on Mon Aug 24, 2009 7:37 pm
Cool. Thanks for the heads up on the stanky smell.
panic_fan
Post by 71_georgia_beetle on Tue Aug 25, 2009 12:42 pm
Hey Rich- I used a Hypo Gear Oil GL4 and it has worked very well. Your trans is roughly the same as mine and you will need just shy of a gallon. 3.65 quarts. I recommend a gallon and a pump. Simple pump until it runs out.
