Java Green 64
Page 4 of 4 Previous  1, 2, 3, 4
Re: Java Green 64
Post by 57RTOval on Tue May 10, 2011 9:01 pm
Looks great! How big is that antenna, 6 feet? Smile
57RTOval
Number of posts : 529
Re: Java Green 64
Post by Attorney Isaiah Loophole on Tue May 10, 2011 10:51 pm
callahan wrote:looks sweet
you wanna buff my car? lol
Bring it down one weekend
Re: Java Green 64
Post by Attorney Isaiah Loophole on Tue May 10, 2011 10:52 pm
57RTOval wrote:Looks great! How big is that antenna, 6 feet? Smile
Close to it hahaha.....and I still get crappy reception on that old radio
Re: Java Green 64
Post by Attorney Isaiah Loophole on Sun Jul 10, 2011 9:12 pm
Eric gave me a Piasa Alton Illinois dealer emblem a while back. Its not a vw dealership but it looks cool. I was going to save it for a ratty car but got an itch to cover up the poorly patched holes in Javas decklid where a dealer emblem was....
Below the tag you can see the poorly patched holes where the dealer emblem was on the decklid at one point
Here it is after I put the badge that Eric gave me on
Now if I will just fix my crooked tag.....
Re: Java Green 64
Post by Attorney Isaiah Loophole on Tue Dec 13, 2011 9:33 pm
I put the glove box pull on that I picked up yesterday.
Re: Java Green 64
Post by Attorney Isaiah Loophole on Mon Apr 07, 2014 11:32 pm
Haven't updated this thread in a while.  I guess I will try and make a big update.  First a couple old and new snow pics.
As for progress on the car....I got tired of the vent windows knocking my mirrors loose and so when I finally found a good deal on some delswifts I picked them up.  I have since added the mirrors on the fenders and removed the threaded hinge pin for a regular one.  I sold my radars off the car to Randy are year or so ago so I could put my silver BRMs back on.
Also installed a Georgia Dubs badge
New steering wheel I picked up today.  Not sure if I am just going to install it or fix the big crack and repaint the outer rim.  Its a little pitted and some of the chrome has peeled but it is perfect for me.
After a quick scrub with some 0000 steel wool
Last edited by Attorney Isaiah Loophole on Mon Jul 20, 2015 12:57 am; edited 2 times in total
Re: Java Green 64
Post by Bugman114 on Tue Apr 08, 2014 12:46 am
What kind of steering wheel is that? Looks killer!
Re: Java Green 64
Post by Attorney Isaiah Loophole on Tue Apr 08, 2014 1:36 pm
Bugman114 wrote:What kind of steering wheel is that?  Looks killer!
Empi Coach Wheel
Re: Java Green 64
Post by Attorney Isaiah Loophole on Mon Apr 21, 2014 1:48 pm
Went ahead and installed the wheel for now.  I think I will repair the crack and repaint the outer rim at some point but I think I will enjoy it for a while until then.
Last edited by Attorney Isaiah Loophole on Mon Jul 20, 2015 12:58 am; edited 2 times in total
Re: Java Green 64
Post by dlandvw3 on Mon Apr 21, 2014 3:00 pm
Attorney Isaiah Loophole wrote:Went ahead and installed the wheel for now.  I think I will repair the crack and repaint the outer rim at some point but I think I will enjoy it for a while until then.
That really does look awesome. That wheel is pretty cool....I'd never seen one like it.
dlandvw3
Number of posts : 479
Re: Java Green 64
Post by ridikas on Tue Apr 22, 2014 12:49 am
That's killer looking Bryce!
Re: Java Green 64
Post by Attorney Isaiah Loophole on Thu Feb 26, 2015 8:42 pm
Decided to change out the 6" beam installed in Java for a 4" beam.  So today I got my spare beam cut apart, cleaned out all the old grease, and welded everything back together.  Needle bearing beams are so much better than urethane beams.  I still have to cut the towers off, narrow the leaves, sandblast and paint!  The 6" beam that is coming out will be used on the truck buggy so with drop spindled disc brakes I can tuck those 6" wheels under the body.
Last edited by Attorney Isaiah Loophole on Mon Jul 20, 2015 12:59 am; edited 1 time in total
Re: Java Green 64
Post by Attorney Isaiah Loophole on Wed Mar 04, 2015 10:47 pm
Towers chopped off and capped and beam is blasted.....waiting to prime and paint until I have some more things ready so I can do them all at once.
Re: Java Green 64
Post by Attorney Isaiah Loophole on Mon Jul 20, 2015 1:03 am
I finished painting and installing the beam a while back.  Even put on a 4" narrowed sway bar!
Drove it to the Griffin Dog House Cruise-In the night before Y U Buggin
Re: Java Green 64
Post by Attorney Isaiah Loophole on Tue Oct 06, 2015 12:03 am
I haven't driven this car much since I went to SOWO in May of 2014.  On the way up I started leaking gear oil in the bell housing.  This caused the clutch to become coated and very sticky.  Also I never fixed the rear wheel bearing that almost locked up on me coming back from Cherokee in 2012.  When it happened we were on the interstate and it felt like we had a flat tire. I ended up getting the car towed home that day. After I unloaded the car off the rollback and unloaded the camping gear the car raised up enough to get oil to the wheel bearing which quieted it down.  So really it has only been local drives since then.  I did purchase an expensive wheel bearing puller a while back and replaced that bearing in like 20 minutes.
Dad said he was willing to drive Java to the Aircooled Therapy session at Bugs 4 Christ this past Saturday so we loaded up both Jave and the ragtop and headed down Saturday morning.  I had already purchased a new clutch kit and input shaft seal for Java.  I also just purchased a rear lap belt and seat belt adapter plugs so Colby can ride in Java.  The plan was to pull the engine and replace the clutch, input shaft seal, re-route the fuel line thru the firewall instead of the front tin and install the seat belt for Colby.  After a long day both cars to do list were marked off!
Re: Java Green 64
Post by zabo on Tue Oct 06, 2015 5:56 am
nice. what bearing puller did you get?
Re: Java Green 64
Post by Attorney Isaiah Loophole on Wed Oct 07, 2015 12:34 am
zabo wrote:nice.  what bearing puller did you get?
I bought the baum type puller that has the interchangeable collets for different bearings.  I bought the body, the extension, and two collets one is specific to reduction gear box transaxles
here is a site I found that has pictures of the tool.  It was not cheap but after using it a few times it was well worth it to me!
Re: Java Green 64
