trans swap
trans swap
Post by zabo on Sun Apr 12, 2009 12:53 pm
I feel like an idiot right now- installed trans put the engine in and then relized I cant get it to shift at all- I cant get it to go into any gear.- I just had the engine bolted in- so i slid it back off the input shaft and still can not shift at all. I had to swap hockey sticks/ nosecones and i cant the hockey stick to budge.
Should I be able to shift through the gears with the engine out?
Re: trans swap
Post by Attorney Isaiah Loophole on Sun Apr 12, 2009 2:19 pm
Yes you should be able to shift through the gears.
what nosecone and hockey stick did you use?
Re: trans swap
Post by zabo on Sun Apr 12, 2009 4:38 pm
got them from WW
nose cone
Re: trans swap
Post by skunk on Tue Aug 25, 2009 11:14 am
hey dude i had the same prob. when i changed the nose cone on mine...theres a 2 lil peaces that looks like lil squears stickin up by the gears when u take the cone off. and in the cone is that lil shaft that is hook shapes with a lil ball on the end..if you dont have that hook shaped shaft layin in the squear shaped peaces with slitts in them correctly then the car want shift into gear right..lol..sorry i dont know what the peaces are called dude.its har to explain..but i hav had the same prob. in the past
skunk
Number of posts : 218
Re: trans swap
