Pulley take off
Page 1 of 1 • Share •
Pulley take off
Gotta take off the crank pulley to put in the breastplate tin. Anyone have a pulley PULLER or another method I can try? Also How do you get a socket wrench on that big ass nut?
Alansd- Dub Noob
- Number of posts : 90
Registration date : 2015-04-30
Re: Pulley take off
Use a wrench on the nut if you can't get a socket on it with the rear tin off. Once that is off, put your hand on one side of the pulley and pull. At the same time, tap the other side with a dead blow. You can use a regular hammer too, just don't hit it as hard. It will move slowly at first. The problem with pullers is they will bend the pulley. And it's almost impossible to use with it in the car.
vw57drvr- Complete Dub Addict
- Number of posts : 898
Re: Pulley take off
ok thanks for that tip
Alansd- Dub Noob
Re: Pulley take off
If that doesn't work, try: http://www.jbugs.com/product/5784.html?Category_Code=vw-specialty-puller-remover-tools
57RTOval- Dub Crazy
- Number of posts : 529
Re: Pulley take off
There is the home-made variety too: http://www.thesamba.com/vw/forum/viewtopic.php?p=7711086
57RTOval- Dub Crazy
Re: Pulley take off
J bug option tool works well.
type4revolution- Complete Dub Addict
- Number of posts : 907
Page 1 of 1
